I have the problem that the long time date from my humidty sensor arent use to calculate humidity plus they dont show up in any lovelace card - the graph simply starts when lts data ends - but it is visible here:
Any clue why this happens?!
Whatever lovelace graph card you are using, it must have explicit support for long-term statistics.
apexchart, history-explorer, plotly custom cards all do.
The builtin “History graph card” doesn’t, afaik, paradoxically.
ahh ok that sounds good - will try with plotly thanks
Ok…I now tried with apex card ….vut got the problem again the graph doesn’t start when it should….
28days offset…
There are more then enough data points…
Any clue why?
this is how it looks
but when i create an ordinary statistics graph card - all values are there but i need more…
Looks like you’re mixing pears and apples.
So that tells you have data up to the 10th June, and the apexchart version seems to show the same.
I suspect no statistics are generated for that sensor. It must have a proper state_class for statistics to be generated (measurement, total or total_increasing)
That’s for another sensor, which has statistics, apparently.
no it ist just for testing purposes i exchanged sensors to see if it works…
if I use the SWITCHBOT BANDED LUFFEUCHTIGKEIT in the APEX chart - data graph doesnt go back until 14th of may…
I have to sensors => Switchbot and Govee - the switchbot uses LTS DATA when longer than 7days the govee always declares any data as HISTORY data…
But none of them works for a correct graph in apex…
Also it doestn using plotly…
I use average sensors which are correctly configured:
Did you ever crack this? I’m having the same problem.
I’m having the same issue.
