Hi all,
I am a little bit confused becahuse I wanted to define a longpress on my enocean button which has been connected voa mqtt from a fhem server.
In works finde, but I am struggling with the long-press. I found a workaround with the trigger.tp_state. but the condition is not working and returns undefined trigger. I do not understand what I have to change in the automation. Can some pls. help to fix this?
alias: Trigger test
description: ""
- platform: state
entity_id:
- binary_sensor.en_ft55_test_on
to: "on"
- platform: state
entity_id:
- binary_sensor.en_ft55_test_off
to: "on"
condition:
- condition: template
value_template: >-
{{ trigger.to_state.last_changed - trigger.from_state.last_changed >
as_timedelta("00:00:01") }}
enabled: true
- if:
- condition: trigger
then:
- type: turn_on
device_id: 4e27115505fd70e30fa465f29e022456
entity_id: light.lidl_edison_bulb_2
domain: light
- if:
then:
- type: turn_off
domain: light
mode: single
Spartacus
