Hello, I’m deciding which cameras to add to my system. I’d like to trigger events based on motion + door sensors (e.g. if there was movement behind the door before it opens, means very likely I’m leaving home; if not, I’m arriving). Also, every time the door opens I take a few snapshots or even a short video clip and save them for some time, in case something strange (like door is open for more than 1min) happens. Is this doable with Blink cameras? I read the movement trigger is not immediately reported to HA?
If not, would you recommend any other setup? So far I’m using plain Dlink IP cameras, but the PIR sensors can’t be reported to HA, so I might select a different brand… I don’t mind having to power them as this is a new flat where I can run power wherever I need.
thanks for the info on this thread, really useful.
