This is the two flows that triggers by the movement of our kitchen TV.
The TV is hung up in the ceiling and pivots down, the sensor mpu6050 x detects the position the TV is in.
About -4 when in “off” position and about 8 when down in viewing mode.
The on sequence has state change node triggering when > 1 and the switch node makes sure it is less than 4.
The off sequence is limited to less than 6 and more than 3 in the state change node and switch node.
After the switch nodes I delay for three seconds and check the new value and in the function node I make sure the TV is going in the correct direction
// current state state change
if (parseFloat(msg.payload2) > parseFloat(msg.payload)+0.2){
return msg;
This means it has to “travel” at least 0.2 in three seconds, which it does.
By some reason I still get an issue where it turns on the TV and then it turns it back off again during the lowering of the TV and when it is in the viewing position (8).
It didn’t do this a week ago.
Now to the question.
Is there a node I can insert that stops all messages for a minute or until I reset it, but only when it comes from the other sequence?
It could block/stop until I reset it or have a “timeout” setting that enables the messages again.
So when the TV on or off command has been sent trigger some node in the start of the other sequence to make sure it can’t run.
I looked at trigger node but it doesn’t seem to be what I want since it either sends something or doesn’t.
Traffic light doesn’t seem to be it either.
It would be great if the node had two inputs, one just for settings and the other for messages. I think that is what I’m looking for.
Everything except the link out, which just triggers the Chromecast
[{"id":"afc82cbf887adc00","type":"server-state-changed","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.mpu6050_accel_x","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"1","halt_if_type":"num","halt_if_compare":"gt","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":240,"y":140,"wires":[["3bcebaa36458666a"],[]]},{"id":"5ac11971ac6530a8","type":"api-current-state","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":2,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":390,"y":220,"wires":[["7c7da31747d87f38"],["6247ff9fd1568205"]]},{"id":"d26fa51342100b18","type":"api-call-service","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":3,"debugenabled":false,"service_domain":"remote","service":"send_command","entityId":"remote.broadlink_4_remote","data":"{\t \"device\": \"kok_tv\",\t \"command\": \"power\"\t}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":860,"y":220,"wires":[["7a419747e53fa09a"]]},{"id":"4326adfa96f28944","type":"delay","z":"341b64864f1ae744","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":620,"y":140,"wires":[["a727c3c669ca795b"]]},{"id":"a727c3c669ca795b","type":"api-current-state","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.mpu6050_accel_x","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload2","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":860,"y":140,"wires":[["571fb9214a348d74"]]},{"id":"571fb9214a348d74","type":"function","z":"341b64864f1ae744","name":"","func":"if (parseFloat(msg.payload2) > parseFloat(msg.payload)+0.2){\n return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":160,"y":220,"wires":[["5ac11971ac6530a8"]]},{"id":"7c7da31747d87f38","type":"delay","z":"341b64864f1ae744","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"x":640,"y":220,"wires":[["d26fa51342100b18"]]},{"id":"3bcebaa36458666a","type":"switch","z":"341b64864f1ae744","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"4","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":140,"wires":[["4326adfa96f28944"]]},{"id":"2c1a4a7f1d0056b7","type":"server-state-changed","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.mpu6050_accel_x","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"6","halt_if_type":"num","halt_if_compare":"lt","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":240,"y":480,"wires":[["ea0e8ddef1dcf984"],[]]},{"id":"8aeab795d9094f8a","type":"api-current-state","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"binary_sensor.tv","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":570,"y":580,"wires":[["e615a481a255558c"],["747140ba04e06e1e"]]},{"id":"e615a481a255558c","type":"api-call-service","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":3,"debugenabled":false,"service_domain":"remote","service":"send_command","entityId":"remote.broadlink_4_remote","data":"{\t \"device\": \"kok_tv\",\t \"command\": \"power\"\t}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":880,"y":580,"wires":[["747140ba04e06e1e"]]},{"id":"747140ba04e06e1e","type":"api-current-state","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":2,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is_not","entity_id":"media_player.chromecast_kok","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":610,"y":660,"wires":[["156d352a3874feef"],[]]},{"id":"156d352a3874feef","type":"api-call-service","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":3,"debugenabled":false,"service_domain":"media_player","service":"turn_off","entityId":"media_player.chromecast_kok","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":920,"y":660,"wires":[[]]},{"id":"a16b05c0f374f625","type":"delay","z":"341b64864f1ae744","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":620,"y":480,"wires":[["2e9ed4b1d16d61c8"]]},{"id":"2e9ed4b1d16d61c8","type":"api-current-state","z":"341b64864f1ae744","name":"","server":"4bbca37b.1700ec","version":2,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","entity_id":"sensor.mpu6050_accel_x","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload2","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":860,"y":480,"wires":[["f81c96b96b413b79"]]},{"id":"f81c96b96b413b79","type":"function","z":"341b64864f1ae744","name":"","func":"if (parseFloat(msg.payload2) < parseFloat(msg.payload)+0.2){\n return msg;\n}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":360,"y":580,"wires":[["8aeab795d9094f8a"]]},{"id":"ea0e8ddef1dcf984","type":"switch","z":"341b64864f1ae744","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"3","vt":"str"},{"t":"eq","v":"unavailable","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":490,"y":480,"wires":[["a16b05c0f374f625"],[]]},{"id":"7a419747e53fa09a","type":"delay","z":"341b64864f1ae744","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":870,"y":300,"wires":[["13ff69ae312c95ef"]]},{"id":"6247ff9fd1568205","type":"change","z":"341b64864f1ae744","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":300,"wires":[["7a419747e53fa09a"]]},{"id":"c2cc7e458e20e984","type":"comment","z":"341b64864f1ae744","name":"Turn on","info":"","x":290,"y":60,"wires":[]},{"id":"ab7bd3b60211914c","type":"comment","z":"341b64864f1ae744","name":"Turn off","info":"","x":310,"y":400,"wires":[]},{"id":"4bbca37b.1700ec","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
