I’m in the process of building a new house and i’m nearing the end of the planning stage for what will be a pretty hefty smart home project. I’m looking for a switch/keypad that looks similar to Lutron’s Palladiom keypad, Leviton Decora style switches or Zooz ZEN32 scene controler. Now here comes the difficult part: It has to support low voltage (<24V) wired protocols, preferably modbus or dry contacts(?). So no latch switch as it won’t be connected to mains but directly to a PLC.
I’ve found some touch switches running on modbus over RS485 marketed for hotels on Alibaba and tested them out (If there is interest i can write a bit more about them and how it works), but i really don’t like the style and they look cheap while costing a lot IMO. I’m leaning more towards an elegant look.
Now in terms of design i only found switches supporting KNX protocol to be close to what i’m looking but KNX is way above my price range and i want something opensource. Now there is a possibility, albeit i have yet to explore it, to use some sort of KNX converter and integrate only switches into the system. If anyone has any experience with that please let me know.
Could you please explain how to integrate those modbus rs485 switches with home assistant? I’ve got a bunch of them but I can’t figure out how to make them work with home assistant.
I lost the original source code and haven’t had much time to install these but i used a esp32 board with rs485 and integrated it using esp home. I’ll mess around with it again in the next week or so and post updates
Hi, Sorry for the tardy reply auto-fitted into junk files box! Yes I have prototypes (currently on Rev3,) I have created a Modbus switch which has 76 registers,
Six buttons and each can be back illuminated red or green. Back illumination is dimmable, Each button records the length of time it has been pressed allowing long press detection. It also measures the cpu temperature, room temprature, Net power voltage, CPU voltage and has an external input terminal for the likes of a door micro-switch for open/shut detection. The external input can also measure analogue inputs, and average the reading over a (programmable) number of readings up to 8000. It is Modbus compatible, with only slight deviations from the full spec. Baud rate is settable. I also incorporated a loudspeaker so it can speak. At power-up it can tell you the baud rate, stop bits parity, and modbus address. I intend it to tell me if the doorbell has been pressed, of if there is a fire which smoke detector has gone off by naming the room, It has a vocab of about 250 words, and other noises. Power supply is D.C 10 to 25 volts, and it consumes about 25mA. It fits into a standard N.Z. plaster depth box, with screw terminals for wiring. I am currently making an I/O box to compliment this switch. This will be used to control various devices, with D.C. and A.C. controls. It will have about 125 registers.
