i have a doorbell, when someone rings, it triggers 12v dc , 300ma , according to screenshot below
so i can make my doorbell smart yey
But i dont have experience with electronical componens, but on this forum i see lots of posts about SonOff wifi components? is that someghing i can use? or is there some other kind of switch
so when someone rings, i can intercept that 12v with a component, i read the state of the component, so its like on/off …
component can be wifi, but i am also running Deconz/Conbee, so maybe a battery powered switch is also ok for me?
I inserted some figures to help you. The ‘voltage source’ is to be what is coming from your doorbell, connect the ‘output’ to the input of a D1 mini. Ensure the grounds are linked
A D1 mini flashed with ESPhome will be easy and better than a Sonoff. All you need is a 5Vdc power supply (micro USB) and a couple of resistors as per my image above. (and a lot cheaper!)
ok, thnx gonna google now
do you also have somekind of image how the end results should look like? i am quite new to lthose boards and resistors, if its not too difficult,i will try
can i also use your same schematic with resistors, but instead the wemos d1 , use a rasperri pi ?
i can then use the PI, also to connect the USB camera from my intercom
