tabooki
(Tabooki)
1
Anybody have a working config for a
ESP32 Development Board CP2102 with a
INMP441 Omnidirectional Microphone?
Just playing around and don’t have a speaker on it yet. Really struggling to get any of the findings posted here working though.
Figured somebody must have one worrying right???
Thanks for any help.
slh
2
See SpotPear "DeepSeek Voice Chat" config and GitHub - RealDeco/xiaozhi-esphome: Alternative code to use xiaozhi ai devices in esphome/home assistant., those devices are esp32-s3+INMP441+max98357a+display, just adapt/ strip down the example to your needs (don’t expect the quality to be sufficient, though).
tabooki
(Tabooki)
3
Between Gemini and grok I came up with this. Seems to work so far.
Blue light turns on when it hears the wake word and blinks when listening for my voice request.
substitutions:
voice_assist_idle_phase_id: '1'
voice_assist_listening_phase_id: '2'
voice_assist_thinking_phase_id: '3'
voice_assist_replying_phase_id: '4'
voice_assist_not_ready_phase_id: '10'
voice_assist_error_phase_id: '11'
voice_assist_muted_phase_id: '12'
esphome:
friendly_name: voice
platformio_options:
board_build.flash_mode: dio
on_boot:
priority: 600
then:
- delay: 30s
- if:
condition:
lambda: return id(init_in_progress);
then:
- lambda: id(init_in_progress) = false;
# Boot LED Test
- logger.log: "Built-in LED Boot Test: ON"
- light.turn_on:
brightness: 1.0
- delay: 1s
- logger.log: "Built-in LED Boot Test: OFF"
- light.turn_off:
- delay: 1s
- logger.log: "Built-in LED Boot Test Complete."
esp32:
board: esp32dev
#variant: esp32s3
framework:
type: esp-idf
version: recommended
components:
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "" # REPLACE with your own key
# Enable OTA updates
ota:
- platform: esphome
password: "" # REPLACE with your own password
wifi:
ssid: "" # REPLACE with your SSID
password: "" # REPLACE with your password
ap:
ssid: "Esp32-Mic-Speaker"
password: "9vYvAFzzPjuc"
captive_portal:
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO33 ##INMP441-WS
i2s_bclk_pin: GPIO18 ##INMP441-SCK
- id: i2s_out
i2s_lrclk_pin: GPIO16 ##Max98357 - LRC
i2s_bclk_pin: GPIO20 ###Max98357 - BCLK
## l/R pin on ##INMP441 is connected to ground
microphone:
platform: i2s_audio
adc_type: external
i2s_audio_id: i2s_in
i2s_din_pin: GPIO13
channel: left
pdm: false
speaker:
platform: i2s_audio
dac_type: external
i2s_audio_id: i2s_out
i2s_dout_pin: GPIO14 ###Max98357 - DIN
#mode: mono
output:
- platform: ledc
pin: GPIO2
frequency: 1000Hz
inverted: true
light:
- platform: monochromatic
output: builtin_led_output
default_transition_length: 0.2s
restore_mode: ALWAYS_OFF
voice_assistant:
microphone: external_microphone
speaker: external_speaker
use_wake_word: true
noise_suppression_level: 4
auto_gain: 26dBFS
volume_multiplier: 1.5
on_wake_word_detected:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
ESP_LOGD("custom", "on_wake_word_detected - Phase: %d, turning on LED for wake word", id(voice_assistant_phase));
id(va_led).turn_on().set_brightness(1.0).perform();
on_stt_end:
then:
- logger.log:
format: "==> Received voice command: %s"
args: [ 'x.c_str()' ]
on_listening:
- lambda: |-
ESP_LOGD("custom", "on_listening triggered - Phase: %d, starting blink for listening", id(voice_assistant_phase));
- script.execute: blink_listening
on_stt_vad_end:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
ESP_LOGD("custom", "on_stt_vad_end triggered - Phase: %d, setting LED dim (waiting to speak)", id(voice_assistant_phase));
id(va_led).turn_on().set_brightness(0.5).perform();
on_tts_stream_start:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
ESP_LOGD("custom", "on_tts_stream_start triggered - Phase: %d, setting LED bright (replying)", id(voice_assistant_phase));
- light.turn_on:
brightness: 1.0
on_tts_stream_end:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
ESP_LOGD("custom", "on_tts_stream_end triggered - Phase: %d, turning off LED", id(voice_assistant_phase));
id(va_led).turn_off();
on_error:
- if:
condition:
lambda: return !id(init_in_progress);
then:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_error_phase_id};
ESP_LOGD("custom", "on_error triggered - Phase: %d, starting flash_error script", id(voice_assistant_phase));
- script.execute: flash_error
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
- lambda: |-
else:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
id(va_led).turn_on().set_brightness(0.3).perform();
on_client_connected:
- if:
condition:
then:
- voice_assistant.start_continuous
- lambda: |-
ESP_LOGD("custom", "on_client_connected wake word branch - Phase: %d, LED off", id(voice_assistant_phase));
else:
- lambda: |-
ESP_LOGD("custom", "on_client_connected muted branch - Phase: %d, setting LED dim (muted)", id(voice_assistant_phase));
on_client_disconnected:
- lambda: |-
id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
ESP_LOGD("custom", "on_client_disconnected triggered - Phase: %d, starting flash_disconnected script", id(voice_assistant_phase));
- script.execute: flash_disconnected
switch:
name: Use Wake Word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- if:
condition:
then:
- lambda: |-
ESP_LOGD("custom", "switch on_turn_on - Phase: %d, LED off", id(voice_assistant_phase));
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- if:
condition:
then:
- voice_assistant.stop
- lambda: |-
ESP_LOGD("custom", "switch on_turn_off - Phase: %d, setting LED dim (muted)", id(voice_assistant_phase));
globals:
- id: init_in_progress
type: bool
restore_value: no
initial_value: 'true'
- id: voice_assistant_phase
type: int
restore_value: no
initial_value: ${voice_assist_not_ready_phase_id}
# SCRIPTS FOR NON-BLOCKING FLASHING AND BLINKING
script:
- id: flash_error
mode: restart
then:
- repeat:
count: 3
then:
- light.turn_on:
brightness: 1.0
- delay: 200ms
- light.turn_off:
- delay: 200ms
- id: flash_disconnected
mode: restart
then:
- repeat:
count: 5
then:
- light.turn_on:
brightness: 1.0
- delay: 100ms
- light.turn_off:
- delay: 100ms
- id: blink_listening
mode: restart
then:
- repeat:
count: 10
then:
- light.turn_on:
brightness: 1.0
- delay: 200ms
- light.turn_off:
- delay: 200ms
Arh
4
For voice to work well you will need at least some psram. Preferably a n16r8 board. As far as I can tell this board does not have that.
And the best place for working code is the examples in this thread.
dionisgr
(Dionisgr)
5
Does the sound work? I’m still practicing, I found your code, but the trouble is, the sound doesn’t even crack.
Arh
6
That is probably due to the board you are trying to use. You may be better off basing your code on this.
wake-word-voice-assistants/m5stack-atom-echo at main · esphome/wake-word-voice-assistants · GitHub
My yaml works fine on the esp32 n16r8, sound plays perfectly.
dionisgr
(Dionisgr)
7
Unfortunately, I only have esp-wroom-32 available + inmp441 + MAX98357A
Arh
8
In my experience you will have audio issues unless you use the N16R8 boards. They tend to crash if using esp32 without psram.
dionisgr
(Dionisgr)
9
Thank you. For the advice.
