Can someone recommend me the wall plug that I can use? I need to connect two devices and be able to turn them on and off as I needed, but I need them to be independent. There are some dual plugs, but I am not sure if I can manage each connection separately.
If anyone uses it, can you please give your feedback and recommendations?
I have that exact unit and can confirm it does exactly what it says. It creates 3 Zwave devices: one for each outlet, and one more for command class scene control.
What does it mean? “command class scene control”? I purchased it and everything looks good, but I cannot figure out what is that third switch for. Can you please explain?
Since the device isn’t fully integrated with OpenZwave, you can’t use it without doing some advanced configuration. Notice that the product type (2500) and id (2500) are “Unknown”.
Until there is support by OpenZwave for this specific device, there’s not much you can do with it. OpenZwave has to support it before we can use it in Home Assistant.
For more information about the Central Scene Command Class, scroll to the bottom of this link:
