I’m looking for a belt winder to automate my window shutters via zigbee. I can’t put a motor directly into the shutters, so I have to use the existing belt. I only found systems from Schellenberg and Rademacher, but they both need additional hubs. As I want to keep the number of additional hubs as low as possible I’m still looking for a belt winder that can be integrated directly via zigbee into home assistant.
I’m currently using deconz II as zigbee controller.
esp8266 → semis D1 Mini connected with opto isolator (German optokoppler) to the belt winder buttons to control up and down, Software will be espHOME.io
May this a solution for your needs? Then I will post / communicate my steps and results.
Thank you for the reply. A while ago, I also find someone using a normal electric belt winder and upgrading it to a smart solution with some microchip - but I couldn’t find the link anymore.
So if you can give an update once you finished it, that would be interesting.
Hi, saw your old Post. Since iam looking for a solution i thought about a similar approach. I Would like to aks if you could provide me more infos about how you made it work.
Thanks in advance.
Stefan
