Looking for Custom Scheduler Component for YAML-Defined Heating Schedules
I am searching for a custom component in Home Assistant that works similarly to the built-in Schedule integration, but is specifically designed to control room heaters (climate entities) by setting temperatures at certain times.
Key requirements:
  • Configuration of the schedules must be possible entirely via YAML.
  • Schedules and thermostats must remain completely separate: I do not want a combined “super thermostat” solution (like Generic Thermostat or similar).
  • It should be possible to define a schedule that applies to multiple days (e.g., all weekdays or the whole week) without having to repeat the same time/temperature entries seven times.
  • It would be very helpful if time blocks could be defined only with start times (no mandatory end times), so the temperature stays active until the next start time is reached.
  • Like the built-in Schedule integration, it should support a “data:” section where I can store additional information (e.g., custom attributes or notes).
Well, I went for the very simple approach, but I only have a single whole-house thermostat.
I have an automation that handles the schedule, and I have a separate script for setting the high/low temps based on the “mode” that that an automation can provide.
Been using it for a year or so like this and it seems just fine. Adding in weekday checks would be easy, but it’s more if anyone is home or not.
I also change the morning heat based on the expected temperature outside. For some reason I don’t need the house as warm when I feel it’s going to be a warm day…
Sometime back I had a different approach where the automation would run ever few minutes and then check what schedule should be running, but I like this way better.
I use the the HA local calendar for scheduling irrigation.
Triggers
triggers:
  - trigger: time
    at: "05:00:00"
  - trigger: time
    at: "07:00:00"
  - trigger: time
    at: "09:00:00"
  - trigger: time
    at: "18:06:00"
  - trigger: time
    at: "20:00:00"
  - trigger: time
    at: "21:30:00"
  - alias: Anytime the away mode toggle changes call the set temp script
    trigger: state
    entity_id:
      - input_boolean.hall_thermostat_away_mode
  - alias: Trigger 'left_home' when zero people home for ten minutes
    entity_id:
      - zone.home
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 1
    trigger: numeric_state
  - alias: Trigger 'back_home' when count of people home is > 0 for two minutes
    entity_id:
      - zone.home
    above: 0
    for:
      hours: 0
      minutes: 2
      seconds: 0
  - alias: >-
      Set 'left_home' mode when a door is open for a few minutes (i.e. turn off HVAC
      when door is open)
    entity_id:
      - binary_sensor.doors_with_sensors
    to: "on"
    for:
      hours: 0
      minutes: 2
      seconds: 0
    trigger: state
  - alias: >-
      And then set 'back_home' (i.e. turn heat back on) when doors are closed
      again for a few minutes.
    entity_id:
    to: "off"
    for:
      hours: 0
      minutes: 2
      seconds: 0
    trigger: state
