Hi, I’m having some issues when trying to set up HomeKit within my configuration.yaml and even in the most basic of configurations it’s not working. I’m stumped here as I’m able to successfully set up via the UI (but don’t want to go down that path because I want to exclude certain globs).
I’m running HA on a Raspberry Pi 4 for background.
Here's my configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
customize: !include customize.yaml
logger:
default: warning
logs:
homeassistant.components.homekit: debug
pyhap: debug
# Text to speech
tts:
- platform: google_translate
# HomeKit
homekit:
auto_start: false
# Includes
group: !include groups.yaml
light: !include light-groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
adaptive_lighting: !include adaptive-lighting.yaml
Note: ideally I would like to do an include for HomeKit and put it in its own file, but in the interest of starting out basic this is where I am.
Logger: homeassistant
Source: components/homekit/config_flow.py:190
First occurred: 9:32:45 AM (1 occurrences)
Last logged: 9:32:45 AM
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 130, in async_init
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/homekit/config_flow.py", line 144, in async_step_import
if not self._async_is_unique_name_port(user_input):
File "/usr/src/homeassistant/homeassistant/components/homekit/config_flow.py", line 190, in _async_is_unique_name_port
if entry.data[CONF_NAME] == name or entry.data[CONF_PORT] == port:
KeyError: 'name'
Would love any help anyone might be able to offer on this as I’m currently blocked from getting HomeKit going as a result!
