I‘m using the Nibe integration recently (so happy that I don‘t need to fiddle around with modbus anymore myself).
I managed to do some basic automation to increase usage of surplus energy mostly for hot water (switching to increased hw demand when surplus >1000W is available). But I‘m looking for more ways to also include heating, etc.
I find it really difficult to find the right start either to go via the modbus aux or directly via the heating curve, or or or…
Anybody found a good way to max out surplus usage of PV for a Nibe?
Main thing I still haven’t found out it: how to trigger the SG-ready interfaces via modbus.
There are no registers directly names sg-ready 1/2. there’s aux1 aux2 but I‘m not sure if they’re the same. Both are available with the Nibe Integration however not as switches but registers with values from 0-61
Hi all. i am looking to automate the PV surplus handling.
I have a NIBE SMOS40 series controller with NIBE F2120 heatpump and I am using the NIBE integration.
Alongside NIBE I have a 20 kW solar installation, I am looking for to inform the NIBE controller for excess solar Power, so maybe It can regulate the power consumption of the heatpump.
For the moment to take advantage of the excess solar power I manually increase the "SMOS40 Heating offset climate system 1 (heating_offset_climate_system_1_40031) to force NIBE to increase water temperature and increase power usage so I can “store” excess solar energy as heating and decrease the need to run the heatpump where there is no solar. I am aware that these practice decrease the efficiency for my Net-Metering but I have a large solar surplus so that is not an issue.
PV panel affects heating (EME) MODBUS_HOLDING_REGISTER 1069 1 4 0 1 0
PV panel affects hot water (EME) MODBUS_HOLDING_REGISTER 1070 1 4 0 1 0
EEV PV (EB101) MODBUS_INPUT_REGISTER 414 10 °C 2 0 0 0
EVI PV (EB101) MODBUS_INPUT_REGISTER 422 10 °C 2 0 0 0
EEV PV (EB108) MODBUS_INPUT_REGISTER 774 10 °C 2 0 0 0
EEV PV (EB107) MODBUS_INPUT_REGISTER 799 10 °C 2 0 0 0
EEV PV (EB106) MODBUS_INPUT_REGISTER 824 10 °C 2 0 0 0
EEV PV (EB105) MODBUS_INPUT_REGISTER 849 10 °C 2 0 0 0
EEV PV (EB104) MODBUS_INPUT_REGISTER 874 10 °C 2 0 0 0
EVI PV (EB104) MODBUS_INPUT_REGISTER 882 10 °C 2 0 0 0
EEV PV (EB103) MODBUS_INPUT_REGISTER 899 10 °C 2 0 0 0
EVI PV (EB103) MODBUS_INPUT_REGISTER 907 10 °C 2 0 0 0
EEV PV (EB102) MODBUS_INPUT_REGISTER 924 10 °C 2 0 0 0
EVI PV (EB102) MODBUS_INPUT_REGISTER 932 10 °C 2 0 0 0
I know that NIBE most of them are propably related to NIBE’s solar inverters (NIBE PV | NIBE).
I hope that those modbus registers can be used to supply SMOS40 with excess Solar power information.
Has anyone managed to make use any of them or has managed to supply SMOS40 with excess solar information to regulate the heatpumps power usage?
Hi, did you get anywhere with this? I have an S325 and S2125 and via Modbus we should be able to get our Solar inverters
to talk to our Nibe system as they’re SG ready?
