Hi all,
I have a lot of smart plugs at home, primarily from Athom, as I have had a great experience with how easy they were to set up since they are pre-flashed with ESPHome and come with power monitoring. Most of them I use them to measure energy consumption of individual devices and tell when they are operating, such as my washing machine so I can have alerts in Home Assistant when finished.
However, Athom now has a V2 of their plugs that has been my new go to, seemingly for good reason, as I have had 4 or 5 V1 plugs of theirs outright die on me. All these plugs were rated for 15A and never exceeded 7A, usually much less. The device they are connected to shuts off, I see them drop off the WiFi, and unplugging and re-plugging them has no effect, no light or power, and the button does nothing.
I programmed all these plugs that I strictly use for monitoring to default to have the Normally-Open (NO) relay closed so that power is available at all times. Perhaps they were never designed to run with power on at all times? I’m hoping this issue was resolved with their V2 plugs, but I haven’t had them long enough to tell and they did not respond to my email.
This leaves me with two main questions:
- Does leaving a NO relay Closed 24/7 have any additional wear on them that could cause these failures? Maybe in the transistors or whatever provides the relay the current to stay closed?
- Does anyone know of any suitable replacements for these smart plugs that come with a relay that is Normally-Closed (NC) and still has Power Monitoring? Like I don’t even need there to be a relay at all for this application. I guess effectively an ESPHome-enabled Kill A Watt is what I’m looking for.
The main reason for this ask is I like to have these plugs to monitor the power usage of devices that could have potentially catastrophic issues if left unpowered and it went unnoticed. Ie. Fridges, Freezers and Sump Pumps. The whole purpose of the power monitoring is to detect when the connected device has failed, but with NO relays I am actually introducing an additional point of failure that would at least mostly be mitigated in my eyes if they were NC.
CTs would not really be an option to my understanding without modifying the power cord of the given devices, so I’m trying to find as simple a solution as I have currently but with a fail safe so that should the smart plug be fried, power continues to flow and only monitoring data is lost.
