What I would like to do is use a Hue wall switch in a push button configuration to control on/off, double click and dimming (changing brightness up and down while the button is pressed).
The Hue wall switch produces left_press
, left_hold
and left_press_release
with Z2M
Here’s a state diagram of the intended implementation:
I’ve been looking around but haven’t been able to find this anywhere. Does someone have something similar running that they can share?
Just to answer my own question. I couldn’t find anything so I ended up doing it myself instead.
Node-RED, AppDaemon and PyScript could probably all be used for the implementation but I decided to go for PyScript. I definitely prefer Python over a visual programming tool/Java and PyScript felt more intuitive than AppDaemon to me.
I didn’t know that there was a left_hold_release
command when I created the first state diagram. I also decided to change the workings of it slightly when I settled on a way to send messages from the @state_trigger
function to the state machine.
I have a bunch of these switches so I also decided wrap it into an app. Really happy that I went with PyScript!
import asyncio
registered_triggers = []
def make_wall_switch_action(config):
action_q = asyncio.Queue(10)
# handles the switch action and adds it to the queue.
@state_trigger(f"{config['switch_id']} == '{config['button']}_press' or \
{config['switch_id']} == '{config['button']}_press_release' or \
{config['switch_id']} == '{config['button']}_hold' or \
{config['switch_id']} == '{config['button']}_hold_release'")
def wall_switch_action(**kwargs):
#log.info(f"{config['switch_id']} {config['button']} button. kwargs == {kwargs}")
try:
# attempt to add the trigger action to the queue.
action_q.put_nowait(kwargs["value"])
except asyncio.QueueFull:
# queue is full (should never happen).
log.error(f"{config['switch_id']} {config['button']} button. Queue is full.")
# the switch state machine that implements the functionality of the switch.
@time_trigger("startup")
def wall_switch_state_machine():
# time in seconds
time_step_size = 0.1
dimming_transition_time = time_step_size * 1.1
full_dimming_time = 2
# timeout iterations
waiting_on_timeout_iterations = int(2 / time_step_size)
waiting_off_timeout_iterations = int(2 / time_step_size)
waiting_double_click_on_timeout_iterations = int(0.4 / time_step_size)
waiting_double_click_off_timeout_iterations = int(0.4 / time_step_size)
double_click_on_timeout_iterations = int(2 / time_step_size)
double_click_off_timeout_iterations = int(2 / time_step_size)
dim_light_timeout_iterations = int(2 / time_step_size)
# initial state for the state machine.
current_state = "idle"
i = 0
while True:
# idle state.
# waiting for an action is blocking (remain in the idle state until an action is available).
if current_state == "idle":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = idle")
# retrieve an item from the action queue (or wait until there is an item available).
action = action_q.get()
if action == f"{config['button']}_press":
# choice.
if state.get(config['light_id']) == 'on':
next_state = "waiting_on"
else:
next_state = "waiting_off"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = idle. Erroneous action received = {action}"
next_state = "error"
# no actions are handled in the error state.
# check if an action is available.
# if yes then rertieve it.
# if no then set action to "none" and continue.
elif current_state != "error":
# retrieve an item from the action queue if one is available (continue if not).
try:
action = action_q.get_nowait()
except asyncio.QueueEmpty:
action = "none"
# waiting_on state.
if current_state == "waiting_on":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = waiting_on")
if action != "none":
if action == f"{config['button']}_press_release":
next_state = "waiting_double_click_on"
elif action == f"{config['button']}_hold":
next_state = "dim_light"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = waiting_on. Erroneous action received = {action}"
elif i >= waiting_on_timeout_iterations:
# timeout.
error_msg = f"{config['switch_id']} {config['button']} button. current_state = waiting_on. Timeout"
# waiting_off state.
elif current_state == "waiting_off":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = waiting_off")
next_state = "waiting_double_click_off"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = waiting_off. Erroneous action received = {action}"
elif i >= waiting_off_timeout_iterations:
# timeout.
error_msg = f"{config['switch_id']} {config['button']} button. current_state = waiting_off. Timeout"
# waiting_double_click_on state.
elif current_state == "waiting_double_click_on":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = waiting_double_click_on")
next_state = "double_click_on"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = waiting_double_click_on. Erroneous action received = {action}"
elif i >= waiting_double_click_on_timeout_iterations:
# timeout.
next_state = "idle"
# waiting_double_click_off state.
elif current_state == "waiting_double_click_off":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = waiting_double_click_off")
next_state = "double_click_off"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = waiting_double_click_off. Erroneous action received = {action}"
elif i >= waiting_double_click_off_timeout_iterations:
# timeout.
next_state = "idle"
# double_click_on state.
elif current_state == "double_click_on":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = double_click_on")
if entry:
# double click action.
# default brightness and default light temperature.
light.turn_on(entity_id=config['light_id'], brightness=config['brightness'], kelvin=config['kelvin'])
next_state = "idle"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = double_click_on. Erroneous action received = {action}"
elif i >= double_click_on_timeout_iterations:
# timeout.
error_msg = f"{config['switch_id']} {config['button']} button. current_state = double_click_on. Timeout"
# double_click_off state.
elif current_state == "double_click_off":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = double_click_off")
if entry:
next_state = "idle"
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = double_click_off. Erroneous action received = {action}"
elif i >= double_click_off_timeout_iterations:
# timeout.
error_msg = f"{config['switch_id']} {config['button']} button. current_state = double_click_off. Timeout"
# dim_light state.
elif current_state == "dim_light":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = dim_light")
if entry:
attrs = state.getattr(config['light_id'])
brightness = int(attrs.get("brightness", 0))
brightness_step_size = int(255 / (full_dimming_time / time_step_size))
dimming_direction = "down"
else:
if dimming_direction == "down":
brightness = brightness - brightness_step_size
if brightness <= 1:
brightness = 1
dimming_direction = "up"
else:
brightness = brightness + brightness_step_size
if brightness >= 255:
brightness = 255
light.turn_on(entity_id=config['light_id'], brightness=brightness, transition=dimming_transition_time)
if action == f"{config['button']}_hold_release":
next_state = "idle"
# reset iteration timer.
i = 0
else:
error_msg = f"{config['switch_id']} {config['button']} button. current_state = dim_light. Erroneous action received = {action}"
elif i >= dim_light_timeout_iterations:
# timeout.
error_msg = f"{config['switch_id']} {config['button']} button. current_state = dim_light. Timeout"
# error state.
elif current_state == "error":
#log.info(f"{config['switch_id']} {config['button']} button. current_state = error")
log.error(error_msg)
next_state = "idle"
# change the state when requested.
# set entry = True (entry into a new state).
# no sleep when changing state.
if current_state != next_state:
# transitions
if current_state == "idle" and next_state == "waiting_off":
light.turn_on(entity_id=config['light_id'])
elif current_state == "waiting_double_click_on" and next_state == "idle":
light.turn_off(entity_id=config['light_id'])
current_state = next_state
entry = True
i = 0
# set entry = False (not entrying into a new state).
# increase iteration timer.
else:
entry = False
i = i + 1
task.sleep(time_step_size)
# register it in the global scope so pyscript sees it.
registered_triggers.append(wall_switch_action)
registered_triggers.append(wall_switch_state_machine)
def wall_switch_action_startup():
#log.info("wall switch action startup.")
for app in pyscript.app_config:
#log.info(f"wall switch action startup. app = {app}")
make_wall_switch_action(app)
