I’m trying to get away from two scripts for on and off with a new wemo. It will be controlling a hot water recirculator. I’ve never had anything with a potential sequence of on delay 30 minutes and off. If anyone has an example script for an action followed by a delayed second action I’d appreciate it.
Post what you currently have.
- service: switch.turn_on
entity_id: switch.YOUR_WEMO
- delay: '00:30:00'
- service: switch.turn_off
Thank you both for writing and @sparkydave for the example.
This is what I drafted up with the intention of three times it’s on for 30 minutes, and then only to be on so long as one of our two phones is detected at home.
- id: '5000000000005'
alias: Hot water recirculation
- platform: time
at: '07:30:00'
- platform: time
at: '09:00:00'
- platform: time
at: '18:40:00'
condition:
- condition: or
conditions:
- condition: device
device_id: b3537ca6e6de81866dad95f9a3e4bf2c
domain: device_tracker
entity_id: device_tracker.pixel_5
type: is_home
- condition: device
device_id: f05b8bb0f7b5f1d39e70ddc602b08f7a
entity_id: device_tracker.pixel_5_gaby
type: is_home
entity_id: switch.wemo_9_recirculator
- delay: '00:30:00'
May have botched the device condition. I’ve seen examples with type “is_not_home” so I just changed to “is_home”.
As long as you are ok with it staying on for that 30 min even if a phone changes to away, because that possibility isn’t currently accounted for in that automation.
Wow mind blown. How do I do that?
One way you could do it is using a wait_for_trigger
. The other is using a while
loop.
Using the wait_for_trigger
- platform: time
at: '07:30:00'
- platform: time
at: '09:00:00'
- platform: time
at: '18:40:00'
condition:
- condition: or
conditions:
- condition: device
type: is_home
- condition: device
type: is_home
- wait_for_trigger:
- platform: state
to: not_home
- platform: state
to: not_home
timeout: '00:30:00'
This should basically wait for one of the phones to change to not_home
but then continue anyway when that fails to occur, so cutting short the timeout if a phone does change to not_home
. Give it a test because it’s not actually something I’ve tried before.
Cool, thank you! I’ll play with this over the weekend.
