Looking for sensors controller compatible with HA - preferably wired
Hello everyone,
I’m new to Home Assistant, but after few days of having fun with it, i really like it.
Until now all my home automations experience was related to enclosed systems like Loxone & Grenton.
It seems that it really can be my main (and the only?) home automation system, but i cannot find/determine best compatible hardware to read any digital and analog sensors like temp, humidity, motion, etc…
I’m looking for any not expensive solution to support 20+ sensors - the best would be some wired DIN controller which can maintain multiple sensors, but it could be also 20+ single controllers for single sensor each if costs really not much.
I was thinking about something like “1-wire to eth/wifi” controller or some controllers supporting digital or analog sensors directly, but i cannot find anything which could not wreck my budget.
Can you guys suggest something or shortly describe your experience stricte with this thread?
P.S. & edit
I found something which looks perfect for my case:
Unfortunately i’ve never heard about this brand and some comments in Web says that devices are failing after one year so i’m a bit afraid to invest time and money in this (especially when they don’t have support and shops in my country).
But these devices perfectly shows what i’m talking about.
hey,
i am also searching for an solution for my future home ;). now i am using a lot of esphome devices (a lot of wifi devices).
i found this on aliexpress:
https://de.aliexpress.com/item/1005003335843526.html?spm=a2g0o.productlist.0.0.2ab64ab8d6PIMu&algo_pvid=5e65ef42-a1a1-4533-b810-01a0805be5ce&algo_exp_id=5e65ef42-a1a1-4533-b810-01a0805be5ce-7&pdp_ext_f=%7B%22sku_id%22%3A%2212000025279608605%22%7D&pdp_pi=-1%3B63.63%3B-1%3B-1%40salePrice%3BEUR%3Bsearch-mainSearch
its nice but i need more than 8 or 16 inputs and outputs. and if i buy several boards i need a connection between them for overarching automations. i want to go sure that the whole home automation system runs without homeassistant.
