Short version: what device should I use to provide valuable voltage for a 6V-12V fan?
Long version: I have a closed enclosure, made of plasterwall, very close to a wall that tends to get wet from water seeping in from outside. (The room is partially under the ground level.) I want to avoid humidity accumulating in this closed space, so that I can avoid mold and other unwanted stuff.
Therefore I have a few ventilation holes on the enclosure, but apparently natural circulation just doesn’t cut it. I have recently introduced a DTH22 sensor, and I see RH values above 80%, which outside this box it’s 50-60%.
So I added 3 fans, all 80x80x15mm, 12V, see here: https://www2.mouser.com/ProductDetail/NMB-Technologies/3106KL-04W-B59-B50?qs=4W3PNmGdEWEvRGqCjBbe%252BQ%3D%3D
My original idea was that I will control the speeds using a Shelly RGBW2, which has 0-12V output, but unfortunately, while great for LED strips, the led controller can’t even move then fans, they just give a whining noise. Different load characteristics, I guess.
So I just gave 12V to the fans, with an on/off switch via a Shell Plus1 relay. This works, but the noise is too much, so I definitely need fan speed control.
But how? Based on the specs, the fan should be able to run between 6V and 13V.
What device should I use to provide valuable voltage for the fan?
Would I have better luck with a Shelly Plus RGBW? (According to the specs, it has PWM speed at 22Khz, as opposed to Shelly RGBW2, which is 960 Hz.)
Or can someone recommend another good device that works nice with HA, with no cloud dependency?
(I am also open to replacing the fans with other models that fit the size, if necessary.)
Thank you.
