I am looking for suggestion on how to mount an old smartphone to a wall.
I plan to use the smartphone as IP camera via the Android IP Webcam component and also as doorbell video call (via MQTT + Tasker + Skype), which will be installed at outdoor.
As such, the mounting solution must be secure and tamper proof.
Any suggestion will be greatly appreciated. Thanks!
But I worry that the metal box will interfere or even block the Wifi and Bluetooth signal. Another thing is I need to drill some holes for the camera, cable and ventilation.
Possibly not. Will depend to an extent what the concrete is reinforced.
I wonder if it is time for a rethink on wifi? You have to run some form of wire for a power supply anyway, why not run ethernet and have a pi with camera in there? You could do POE and get away with one cable.
Trouble is POE doesn’t usually help with andoid/ios phones as they don’t do wired ethernet, but there are POE tablets on Aliexpress.
Other than IP camera, I want to use it as video call via Skype when someone presses the doorbell. I plan to use Tasker to automate the video calling after receiving command from HA via MQTT.
Other than Wifi, I also need Bluetooth to connect the phone to my Jabra Speak 510 via Bluetooth. This will improve the sound and mic quality tremendously.
Another obstacle is the location makes it hard for me to drag an Ethernet cable.
I wish there is an Android device with camera support, ethernet connection and USB ports for wired speakerphone such as Jabra Speak 410.
i think nothing is really secure, a smartphone is not secure, and is easy to break.
the same for tamperproof … maybe add a little rooftop in plexiglass, but a old smartphone is not humidity resistant.
So the more simple will be the best.
