Can anyone recommend a good HVAC thermostat that works well with Home Assistant? My wife wants to be able to turn the heat on in the morning from our bed and I would like it to be non-cloud based.
I’ve found what I think may be two possible candidates:
Auto heat/cold
Remote thermometer can be used
Totally local
The thermostat is in the hallway. Before putting this in, the living room was always off and not comfortable. Using a Zigbee thermometer in the living room, I have an automation in HA that sets the ‘current’ temperature for the thermostat.
I also have automations that set the wanted temperature for both day and night. Basically, morning and night scripts. I get up earlier than she does. So, I run the morning script. She runs the night script. We always keep it on heat/cool. The morning script sets the heat/cool settings up and the night one sets the heat/cool settings down.
I’m new to this forum and quite unfamiliar with its organization. I have done several searches and came up empty handed. Is there a specific sub-forum or category or tag or whatever that I should use to locate the info you say is there?
