Hi all,
I was searching the forum and on google for solutions where I can use water to cool down one room. One must - must be controllable via HA
So what I am looking for is a internal unit which basically is a air-water heat exchanger with a fan.
I don’t need it for heating - therefore an internal unit from a split HVAC seems to be a bit too much for my purpose.
Any ideas if there is a affordable ready to go unit or if anyone has built a DIY solution?
As a side note - I don’t need to cool down the water - I do have access to ground water which is between 4 and 10 °C all the time. That should be cold enough to cool down that room by 5 - 10 degrees.
Thanks.
