Any recommendations gratefully received. Needs to work with ZHA.
The Aqara T1M looks possible, but is expensive compared to others out there like the govee and tuya ones, but I’ve not found any good info on which devices work with ZHA and can be properly controlled.
The ones I’ve looked at so far, seem to have problems with either both lights (main and accent) being controlled as a single light, or lights where the effects don’t work unless controlled through the native app.
I experimented with these and they worked fine with zigbee2mqtt, this was a year or so ago. USD 20 price range. I ended up going with a Tuya based MCU device that I was able to replace the firmware to make it 100% local wifi using OpenBK7231T/OpenBeken (I am pretty sure ESPHome’s Tuya MCU support will work as well). I went with this Tuya light because it offered a greater form acceptance from the ‘significant other’ I think with a little bit of AliExpress searching you can find other Zigbee lights that might work for you as well. Since you are down the ZHA rabbit hole, you might need to do a custom quirk. For this light, I do not remember if I could control the ‘whites’ and ‘RGBs’ separate on the zigbee light (zigbee is bit more restrictive on light control than a custom Tasmoto or ESPHome device) , on the Tuya WiFi hacked light they are separate physical LEDs and can be controlled independently and at same time. Good hunting!
What it configured itself as under Zigbee2MQTT and link to the Zigbee2MQTT database entry:
Friendly name
0xa4c138ee9ddce237
Description
Last seen
3 minutes ago
Availability
Online
Device type
Router
Zigbee Model
TS0505B
Zigbee Manufacturer
_TZ3210_mja6r5ix
Description
Zigbee RGB+CCT light
Support status
Supported
IEEE Address
0xa4c138ee9ddce237
Network address
0xDEA3
Firmware version
z.1.0
Manufacturer
TuYa
Model
TS0505B_1
Power
Interview completed
True
zigbee2mqtt doc for TuYa TS0505B_1
https://www.zigbee2mqtt.io/devices/TS0505B_1.html#tuya-ts0505b_1
@Rofo which ceiling light did you choose in the end and are you happy with it? I am currently looking for zigbee ceiling lights and bought one of these Tuya ones from ali express. The light itself works, however the connection is a little bit flaky as the zigbee module seems to be veryyy cheap and the connection quality is very low even though its neighbours are close.
See the connections speeds of the lamp in the bottom right.
I bought one for $13 (the one @dproffer recommended in his answer). I’d be willing to spend more (~$30-$40) however all those zigbee lights on aliexpress seem to be the same one and the ones on amazon (e.g., philips hue) costs > $100.
