Can anyone help with a lookup table sensor, I cant get it to work, I need it to ready the cm height and convert it to volume.
- sensor:
sensors:
oil_volume_liters:
friendly_name: "Oil Volume"
unit_of_measurement: "L"
value_template: >
{% set depth_cm = states('sensor.liquid_depth') | float %}
{% set lookup_table = {
1: 11.309776720584
2: 22.619553441168
3: 33.929330161752
4: 45.239106882336
5: 56.54888360292
6: 67.858660323504
7: 79.168437044088
8: 90.478213764672
9: 101.78799048526
10: 113.09776720584
11: 124.40754392642
12: 135.71732064701
13: 147.02709736759
14: 158.33687408818
15: 169.64665080876
16: 180.95642752934
17: 192.26620424993
18: 203.57598097051
19: 214.8857576911
20: 226.19553441168
21: 237.50531113227
22: 248.81508785285
23: 260.12486457343
24: 271.43464129402
25: 282.7444180146
26: 294.05419473519
27: 305.36397145577
28: 316.67374817635
29: 327.98352489694
30: 339.29330161752
31: 350.60307833811
32: 361.91285505869
33: 373.22263177927
34: 384.53240849986
35: 395.84218522044
36: 407.15196194103
37: 418.46173866161
38: 429.77151538219
39: 441.08129210278
40: 452.39106882336
41: 463.70084554395
42: 475.01062226453
43: 486.32039898511
44: 497.6301757057
45: 508.93995242628
46: 520.24972914687
47: 531.55950586745
48: 542.86928258803
49: 554.17905930862
50: 565.4888360292
51: 576.79861274979
52: 588.10838947037
53: 599.41816619095
54: 610.72794291154
55: 622.03771963212
56: 633.34749635271
57: 644.65727307329
58: 655.96704979388
59: 667.27682651446
60: 678.58660323504
61: 689.89637995563
62: 701.20615667621
63: 712.5159333968
64: 723.82571011738
65: 735.13548683796
66: 746.44526355855
67: 757.75504027913
68: 769.06481699972
69: 780.3745937203
70: 791.68437044088
71: 802.99414716147
72: 814.30392388205
73: 825.61370060264
74: 836.92347732322
75: 848.2332540438
76: 859.54303076439
77: 870.85280748497
78: 882.16258420556
79: 893.47236092614
80: 904.78213764672
81: 916.09191436731
82: 927.40169108789
83: 938.71146780848
84: 950.02124452906
85: 961.33102124964
86: 972.64079797023
87: 983.95057469081
88: 995.2603514114
89: 1006.570128132
90: 1017.8799048526
91: 1029.1896815731
92: 1040.4994582937
93: 1051.8092350143
94: 1063.1190117349
95: 1074.4287884555
96: 1085.7385651761
97: 1097.0483418967
98: 1108.3581186172
99: 1119.6678953378
100: 1130.9776720584
101: 1142.287448779
102: 1153.5972254996
103: 1164.9070022202
104: 1176.2167789407
105: 1187.5265556613
106: 1198.8363323819
107: 1210.1461091025
108: 1221.4558858231
109: 1232.7656625437
110: 1244.0754392642
111: 1255.3852159848
112: 1266.6949927054
113: 1278.004769426
114: 1289.3145461466
115: 1300.6243228672
116: 1311.9340995878
117: 1323.2438763083
118: 1334.5536530289
119: 1345.8634297495
120: 1357.1732064701
{% set target = 71 %}
{% set ns = namespace(diff=float('inf'), depth=None) %}
{% for d in lookup_table.keys() %}
{% set cur_diff = (d - target) | abs %}
{% if cur_diff < ns.diff %}
{% set ns.diff = cur_diff %}
{% set ns.depth = d %}
{% endif %}
{% endfor %}
{% set nearest_depth = ns.depth %}
{% set volume_liters = lookup_table[nearest_depth] %}
{{ volume_liters }}
I just get an error in HA
- Invalid config for ‘template’ at configuration.yaml, line 82: ‘sensor’ is an invalid option for ‘template’, check: sensor->1->sensor Invalid config for ‘template’ at configuration.yaml, line 82: required key ‘state’ not provided
- Invalid config for ‘template’ at configuration.yaml, line 83: ‘platform’ is an invalid option for ‘template’, check: platform Invalid config for ‘template’ at configuration.yaml, line 88:
