Hi @ all.
I need a bit of help with this automation:
turn on my heat-pump if PV-Inverter-Room temperature is too hot (above 35°) and if there’s enough solar pv production and battery charge is >55%.
Then automation must turn off Heat-Pump if after 1 hour PV-Inverter-Room temperature will be below 32° or loop until temperature will be below 32° and when it will append turn off heat pump.
Can do all I want by this code or there’s something wrong? Thanks 4 help in advance.
alias: PV-Inverter-Room Automatic air conditioning (test)
description: PV-Inverter-Room Automatic air conditioning if temperature is too hot
- platform: numeric_state
entity_id: sensor.ventola_mansarda_temperature
for:
hours: 0
minutes: 5
seconds: 0
above: '35'
condition:
- condition: numeric_state
entity_id: sensor.battery_state_of_capacity
above: '55'
entity_id: sensor.energy_next_hour
above: '1.50'
above: '35'
- service: notify.mobile_app_smartphone_michele
message: >-
La Temperatura del locale tecnico è ELEVATA ed è pari a {{
states("sensor.ventola_mansarda_temperature") }} °, avvio
climatizzazione
title: >-
Temperatura Locale tecnico di {{
- service: climate.turn_on
entity_id: climate.altherma
data: {}
- delay:
hours: 1
minutes: 0
seconds: 0
milliseconds: 0
- if:
below: '32'
then:
- service: climate.turn_off
data: {}
else:
- repeat:
until:
below: '32'
sequence:
data: {}
mode: single
