apas
(apas)
November 4, 2022, 1:34pm
1
hello to all
i have read many, many threads, but i still dont understand:
how to call service in a loop ?
pseudo code:
- alias:my_scrpit:
anything
array=[item1, item2, item3]
for item in array
call service
data= item
endfor
looks simple…
possible ?
not possible ?
other ways ?
Many thanks for all answers.
apas
(apas)
November 4, 2022, 1:50pm
3
@123
i have missed this one…
clever (i put 1 )
but what if adding some test|additions|… on item:
pseudo code (more difficult i think)
- alias:my_scrpit:
anything
for item in array
if item > test_variable
call service
data= item
endif
endfor
123
(Taras)
November 4, 2022, 1:53pm
4
You can use if - then
(within the repeat - for_each
) to determine if the service call should be executed or not.
apas
(apas)
November 4, 2022, 2:00pm
5
@123
i believe this is how to get dynamic values
obviously there is no need to test or something in static array
- repeat:
for_each:
- e: switchlinc_dimmer_3d_ac_8a
b: states('input_number.test')
- e: lamplinc_dimmer_35_54_23
b: 50
sequence:
- service: light.turn_on
entity_id: 'light.{{ repeat.item.e }}'
brightness_pct: '{{ repeat.item.b }}'
right ?
but where to put if|then|else ?
123
(Taras)
November 4, 2022, 2:14pm
6
The following example executes the service call only if the light is currently off
- repeat:
for_each:
b: "{{ states('input_number.test') }}"
b: 50
sequence:
- variables:
entity: 'light.{{ repeat.item.e }}'
- if: "{{ is_state(entity, 'off') }}"
then:
entity_id: '{{ entity }}'
apas
(apas)
November 4, 2022, 2:27pm
7
@123
clean & smart !
i think you have read this before, but you are a genius.
i will read & reread & try to integrate in my project
many thanks, you find the solution in minutes, i have search this for # 48 hours !!!
