Loop in script with variables
i try to pass an variable as array in a script and loop all items of the array as mqtt topic. But the mqtt command has Not the correct variable in the topic path. I hope someone can help me on this. Here is the automation and the called script.
AUTOMATION:
alias: Tablets bei Bewegung an
description: ''
  - platform: state
    entity_id: binary_sensor.flursensor_occupancy
    to: 'on'
condition: []
  - service: script.tablets_bei_bewegung_an
      rooms:
        - wohnzimmer
        - ankleide
        - schlafzimmer
        - bad
        - kueche
mode: single
SCRIPT:
sequence:
  - service: mqtt.publish
      topic: >-
        {% for room in "{{ rooms }}" %}
        "wallpanel/{{ room }}/command"
       {% endfor %}
      payload: '{"wake": true, "wakeTime": 3600}'
mode: single
You can’t nest one template inside of another one.
Try this version:
EDIT
Suggestion withdrawn.
I changed the loop as you suggested but now it seems the script does not enter the loop. There is no mqtt message in my mqtt output
I removed my initial suggestion because the whole approach you’re using won’t work. You can’t loop through several topics that way and expect one service call to publish to multiple topics.
You need to use repeat to execute the service call multiple times (once for each topic). I recently provided a similar example here:
Let me know if you need help to adapt the example for your application.
This works perfect. Thank you. Here is my working automation
description: ''
  - platform: state
    to: 'on'
condition: []
  - variables:
      rooms:
        - wohnzimmer
        - schlafzimmer
        - bad
        - kueche
  - repeat:
      count: '{{ rooms | count }}'
      sequence:
        - variables:
            room: '{{ rooms[repeat.index - 1] }}'
            topic: |
mode: single
