Loop MQTT msg every 10 mins while sensor = X
I don’t see how to post code keeping the correct indents…wait i think i got it. First hit preformatted text, then blockquotes.
I want to send a MQTT msg every 10 mins when my aquarium temp or sump temp falls out of a range and not send it when its not. The device that’s monitoring the temps is capable of sounding a alarm via mqtt msg.
This is the automation part so far, it sends a text msg to my phone… Actually just tested and its not working :frowning:
  - alias: 'Temp Alarm'
      platform: numeric_state
      entity_id: sensor.tank_temp
      above: 79
      below: 75
      - service: notify.Sms_alert
          message: 'Aquarium Temp is {{states.sensor.tank_temp.state}} and Sump is {{states.sensor.sump_temp.state}}'
            - +1xxxxxxxxxx
Is there a better way then something like this “How can repeat this automation? - #2 by PhyberApex”, that process just seems long.
The part i plan to adapt is:
automation:
  - alias: 'Porta casa de banho'
      platform: state
      entity_id: binary_sensor.porta_casa_de_banho
      state: 'on'
      for:
        seconds: 20
      - service: script.stuff
script:
  stuff:
    sequence:
      - condition: state
        state: 'on'
      - service: shell_command.play_wc
      - service: script.stuff_loop
  stuff_loop:
    sequence:
      - condition: state
        state: 'on'
      - delay:
          seconds: 20
I would use time every 10 mins as the trigger and the temps as the condition and your script as the action.
Would that mean if temp falls out of range, then I may need to wait 10 mins before hearing the first alert?
btw…
is this the correct way to call the action
      above: 79
      below: 75
You can add the state change of the “alarm via mqtt msg” as another trigger to get a instant notification.
I somewhat followed that link, no scripts, i put this in automations which i believe should yield a notification…
  - alias: 'Temp Alarm 2 test'
      platform: time
      minutes: '/2'
    condition:
      - condition: numeric_state
        above: 79
        below: 75
            - +1xxxxxxxxxx
could the issue be the sensor is read as 73.39 and i’m only putting 75 for instance… it should be
condition:
    above: 79.00
    below: 75.00
You can optionally use a value_template to process the value of the state before testing it. This should change it to an integer.
condition:
  entity_id: sensor.temperature
  above: 17
  below: 25
  # If your sensor value needs to be adjusted
  value_template: {{ int(state.state) }}
You can test the automation in the state dev page by going to the sensor and changing the temp to see if it triggers.
      - platform: time
        minutes: '/2'
      - platform: numeric_state
    # Optional
       # value_template: '{{ int(states.sensor.tank_temp.state) }}'
        above: 79
        below: 75
    condition:
        above: 79
        below: 75
            - +1xxxxxxxxxx
Error “invalid key: “OrderedDict([(‘int(state.state)’, None)])”
in “/home/homeassistant/.homeassistant/automations.yaml”, line 36, column 0”
does it work without that line?
did you try to use this commented line?
# value_template: ‘{{ int(states.sensor.tank_temp.state) }}’
did you try above: 79.00 below: 75.00 ?
gives me “Template error: UndefinedError: ‘int’ is undefined”
and this also does not work.
      - platform: time
        seconds: '/5'
       # value_template: {{ int(state.state) }}
    # Optional
        above: 79.00
        below: 75.00
    condition:
        above: 79.00
        below: 75.00
        #value_template: {{ int(state.state) }}
I have decided to edit the code on controller “esp9266” to sound alarm instead as this would be more reliable also.
Thank you for your help.
