vormsty
(Vormsty)
September 6, 2019, 2:53am
1
I want to loop on a script while a bolean value is true
I will run a “light show” while a button on the panel is on
The variable on the panel is input_boolean.start_light_show_1
I will send a mqtt publish every second while the boolean is true.
Can any body guide me for the realisation of my first script ?
master:
- condition: state
entity_id: input_boolean.start_light_show_1
state: 'on'
- service: script.turn_on
entity_id: script.rainbow1
rainbow1:
sequence:
- service: notify.pushbullet
title: "Light show"
message: "Rainbow1 in script"
- service: mqtt.publish
topic: "cmnd/b0704d58c57d3b4bbacadaf645505c4/color"
payload: "effect: rainbow1"
- delay: '00:01:30'
entity_id: script.master
Many thanks for your help and best regards
Thierry
Tinkerer
(aka DubhAd on GitHub)
September 6, 2019, 6:46am
2
Other than some formatting issues (you’ve got indents of two, three, and five spaces) the logic there is good.
If after you fix the formatting you’re having problems, please show us your code and explain the problem.
The indentation, although legal YAML, is not conventional. But I think the real problem is you forgot sequence:
in the master
script. Try:
master:
sequence:
- condition: state
state: 'on'
rainbow1:
sequence:
title: "Light show"
- delay: '00:01:30'
There is also the possibility that that you need at least a small delay in the master
script between the existing two steps. But give the above a try first.
vormsty
(Vormsty)
September 7, 2019, 12:19am
4
many thanks for your help !
Best regards
Thierry
rccoleman
(Rob Coleman)
September 7, 2019, 1:44am
5
I would use an automation and a time_pattern trigger instead of a script:
- id: 'Cycle colors'
alias: Cycle colors
initial_state: true
- platform: time_pattern
seconds: '/1'
condition:
- condition: state
state: 'on'
vormsty
(Vormsty)
September 7, 2019, 4:45pm
6
Ouahhhhhh!
Many thanks for your help!
I will try it tomorrow!
Best regards!
