In an automation that is triggered by a humidity sensor I want to do the following
- turn on the heating
- wait until either 20 minutes have passed or a certain temperature is reached.
I haven’t found a good way of coding this second step
What do you want to happen when this second step is achieved?
Turn it off again? If so, I’d suggest a second automation with two triggers (which are OR by default):
on
(or whatever state you see) for 20 minutesOf course, the first automation might turn it straight back on again…
There are a bunch of actions running before this and another bunch of actions after this.
And no, I don’t want to put this in a second automation as this is not something that should run independently
Long-running actions are often not a good idea as they’re prone to interruptions with HA restarts, reloads etc.
If you must do this, try wait_for_template
or wait_for_trigger
to test the temperature (docs), with a 20 minute timeout
The most reliable way to incorporate an extended period of waiting is to use a timer instead of adding delays or other wait actions to your automation. This can be combined with other triggers by using a Choose action or templates.
- platform: numeric_state
entity_id: sensor.humidity
above: 60
for: "00:01:00"
entity_id: sensor.temperature
above: 75
for: "00:01:00"
- platform: event
event_type: timer.finished
event_data:
event_id: timer.humidity
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: HOWEVER YOU TURN ON YOUR HEATING
- service: timer.start
entity_id: timer.humidity
duration: "00:20:00"
- conditions:
sequence:
- service: HOWEVER YOU TURN OFF YOUR HEATING
Just a small clarification, as of version 2022.11, automations and scripts that are in-progress are not terminated by reloading automations/scripts.
Reference: Smarter Reloading of Automations and Scripts
Restarting Home Assistant will, of course, terminate in-progress automations and script.
My current trigger is the closing of the window. As mentioned I don’t want this to go off all the time so I’m not sure how to combine what I want with what you wrote…
I currently had the script below with 2 parallel actions but this complete both fully before continuing…
alias: Onze Slaapkamer ontvochtigen
description: ""
- type: not_opened
platform: device
device_id: d911041a0e31de814c11ca3ba36ed206
entity_id: binary_sensor.raam_onze_slaapkamer_on_off
domain: binary_sensor
for:
hours: 0
minutes: 0
seconds: 10
condition:
- condition: and
conditions:
- condition: numeric_state
entity_id: sensor.vochtsensor_onze_kamer_humidity
above: 60
entity_id: sensor.airco_onze_slpk_room_temperature
below: 16
- service: script.airco_onze_slaapkamer_heat
data: {}
- parallel:
- delay:
hours: 0
minutes: 20
seconds: 0
milliseconds: 0
- repeat:
while:
entity_id: climate.airco_onze_slpk
attribute: current_temperature
below: 16
sequence:
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- service: script.airco_onze_slaapkamer_off
data: {}
mode: single
It’s all a matter of setting up your conditions to keep your scripts from being fired when you don’t want them to. The basic outline would be something like what follows. You may need to add other conditions to the second option of the Choose to control when the “turn off” script is fired.
description: ""
- type: not_opened
platform: device
for:
hours: 0
minutes: 0
seconds: 10
below: 16
- platform: event
event_data:
event_id: timer.slpk_airco
condition: []
- choose:
- conditions:
above: 60
below: 16
sequence:
data: {}
entity_id: timer.slpk_airco
- conditions:
sequence:
data: {}
- condition: template
value_template: "{{ trigger.platform == 'numeric_state'}}"
- service: timer.cancel
