TL;DR - I need to figure out a way to have an action button that calls script 1, wait 10 mins, call script 2, wait 10 mins and call script 1 again - and keeps repeating in a loop
Additional details
I have a IR controlled HVAC which seems to have a busted thermostat
It seems to be cooling my study room to frigid temperature then cut out and then waits till it gets way too warm.
As much as I would like to get it fixed, the current COVID restrictions in my country make it impossible - and in any case not advisable till things get back to normal
To create a workaround, I setup two scripts on a Harmony hub in the room
Script 1 - Turns on the HVAC cooling mode
Script 2 - Turns off the HVAC mode
Then I created a third script (Script 3) that :
- Calls script 1
- delay 15 mins
- calls script 2
- Delay 15 mins
and I manually repeated that loop multiple times (only 2 loops in code below)
study_aircon_loop_mode_action:
alias: Study Aircon Loop mode action
sequence:
- service: script.script_ht_aircon_jetcool
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- service: script.script_ht_aircon_off
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
Now I am sure there are more elegant ways to do this - but even this should have worked
However the script seems to stop after the 1st loop with the HVAC in off mode.
Any suggestions?
