Could someone please consider adding the “guest_access_mode” API feature to the integration found at:
It appears that the documentation mentions the ability to enable or disable guest mode using this API, but this feature is not currently implemented in the addon. You can refer to the documentation under the “call the api” paragraph for more details:
guest_access_mode (1 if enabled, 0 if disabled)
Thank you for considering this enhancement request!
