I got a digital water meter that works with LoRa 868Mhz.
Does anyone know a good gateway to integrate it into a home-assitent?
Maybe, you already have an open network in your region, you just need to integrate it to it, rather than building a private one.
Unfortunately not, the water department drives through the village once a year and reads the meters from the car.
The meters are not connected to the internet.
Since the meter is not in the house but in a shaft, I would like my home assistant to read it via LoRa in order to detect a burst pipe.
I think @anon63427907 means a Lora network, something like https://www.thethingsnetwork.org/
Yes, exactly what i was supposed to say
I am in a similar situation. the plumber just installed water meters with Lora capability (bmeters hydrodigit-S1)
How can I know if a lora network already exists and what do I need to connect and get the readings in HA?
I am also investigating this. Did you find any solution?
unfortunately no.
Just got one today. Following in case this gets an update.
Check out this topic for a example Lora addon for HA.
Needs to be made generic, but it is a start…
