Hello, I am looking at a Zigbee roller shutter I can use in Home Assistant through my Zigbee2MQTT (coordinator is Sonoff Dongle-E).
I looked at Loratap SC500ZB as I use other Loratap and seems pretty “intimate” with HA.
I would like to know if anybody of you is using such a component and if it was possible to calibrate the component. As alternative, can you gently suggesting a Zigbee Roller Shutter you are happy with using the same stack (Zigbee2MQTT, HA, non external hub).
Thanks for the contribution.
