Losing connection
I noticed sometimes it seems like homebridge is losing it’s connection to HASS. When this happens the Apple Home app shows “updating” on all devices. Usually it reconnects after 20-30 secs and it starts working again. Unfortunatly reconnection doesn’t occur in the background, i have to open the Home app to reconnect.
It seems like the HASS iOS app also loses his connection at the same time because it also has to be reconnected by pushing the Save button and then the Done button.
I don’t know if these two problems are related but so far it seems like HASS is droping all connections once in a while.
So far haven’t found any errors in the logs. What could be causing this and where to start troubleshooting?
i have the same problem. is there a fix?
