Just updated to 115 and homeassistant-wise everything is working, but if I try and open the web-ui for the vsc addon I get “Error while loading page ingress.”
Additionally trying to open the configuration pages for any of my addons in the supervisor tab just gets “Error while loading page addon.”
I presume this is a supervisor thing, but there’s no errors in any of the logs. I tried reloading the supervisor but no change.
Hmmm, this is odd. I’m only getting this in the homeassistant android app, chrome is working fine. Given that the android app is just a chrome webview I can’t see why there’s a difference
I actually got mine to work now, after an hour of messing about.
I had to remove this from my config, and then clean the cache in my browser for my domain and everything started working again.
I’m not home until tomorrow so can’t access my configuration to make changes, but as I said it is only happening in the homeassistant android app not if I connect via a browser (obviously remotely, can’t check local).
Appreciate the insight though and will have a look at trusted network tomorrow, although I don’t think I use it (from memory).
I always close the app fully (Swipe away from recent apps) but that hadn’t had any effect. After reading your post I’ve just cleared the application data and restarted the app from scratch and aside from the inconvenience of setting it all up again, it is now working so it looks like it was some kind of caching glitch in the app.
I have a similar problem
going to ha cli I see my installed addons
going via frontend, clicking on xy/hassio or any addon, empty frame → popup wait or leave.
If i do the same on my mobile, not via app, it works.
I have cleared the cache in chrome
I have tested a new installation in virtualbox, after that I saw this issue the first time. Then back to prod system, now there I have the same issue
Any idea?
