Update: Restored last backup and recreated automations and the problems did not come back.
I am getting the following error in my logs
Unable to set up dependencies of default_config. Setup failed for dependencies: automation
I was adding a new automation via the gui and after I saved it all my automations were greyed out. I tried removing them and recreating them, but they don’t show in the GUI. They do end up in my automations.yaml file.
How do I get automations back up and running. I have rebooted several times.
Entire error
File "/usr/src/homeassistant/homeassistant/setup.py", line 229, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 230, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 635, in _async_process_config
await async_validate_config_item(hass, raw_config),
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 86, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 241, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 298, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 256, in async_validate_action_config
platform = await device_automation.async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 112, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration '' not found
2022-01-28 10:50:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: automation
2022-01-28 10:50:13 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2022-01-28 10:50:17 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'float' got invalid input 'unknown' when rendering template '{% set direction = ['N','NNE','NE','ENE','E','ESE','SE','SSE','S','SSW','SW','WSW','W','WNW','NW','NNW','N'] %} {% set degree = states('sensor.weather_station_wd')|float %}
{{ direction[((degree+11.25)/22.5)|int] }}' but no default was specified. Currently 'float' will return '0', however this template will fail to render in Home Assistant core 2022.1
2022-01-28 10:54:20 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/config/automation.py", line 22, in hook
await hass.services.async_call(DOMAIN, SERVICE_RELOAD)
File "/usr/src/homeassistant/homeassistant/core.py", line 1442, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Unable to find service automation.reload
Thanks for the help
