I have the following issue and somehow I am not able to figure out a solution.
I got a new router since the one provided by ISP is horrible. Thus, I now have the ISP router in bridge mode to be used as modem and my own router connected to that.
However, this made me loose access to HA, I just cannot access the login screen anymore.
I can assume it is because I might have set a static IP in the HA settings. Unfortunately I cannot assign this IP to HA with my new router, as the new router receives its IP from the modem.
I cannot change the IP range in my router to the one used before since it would be identical to the IP range of the modem.
Guess there is no other way than resetting the ISP router and modify HA settings. Thanks for the hint
