It looks like my frigate nvr has filled the disk with clips overnight. I just want to know how can I access the drive in order to delete the clips in the folder and change the config, so this won’t happen again.
I can’t access shares over samba and can’t access over ssh any more.
I have backups, but I only want to use that option as a very last resort.
I tried already mounting flash storage through live Ubuntu image, but couldn’t set permissions to delete clips in the media folder.
At least I was able to copy my Node-Red folder - the last thing that was modified since yesterday’s morning backup.
So now I am restoring my backup, can’t have anything in non-working state longer than few hours.
I was hoping the media folder would be easily accessible and writable outside of Home Assistant when storage is physically connected to another PC. Anyway, thanks for a suggestion.
Well too late now, I flashed a new image and tried to restore my backup only to discover none of them are working… When I type my password HA restarts and returns errors in supervisor:
File "/usr/src/supervisor/supervisor/backups/manager.py", line 251, in _do_restore
backup.restore_homeassistant()
File "/usr/src/supervisor/supervisor/backups/backup.py", line 467, in restore_homeassistant
self.sys_homeassistant.refresh_token = self._decrypt_data(
File "/usr/src/supervisor/supervisor/backups/backup.py", line 212, in _decrypt_data
data = padder.update(decrypt.update(b64decode(data))) + padder.finalize()
File "/usr/local/lib/python3.9/site-packages/cryptography/hazmat/primitives/padding.py", line 159, in finalize
result = _byte_unpadding_check(
File "/usr/local/lib/python3.9/site-packages/cryptography/hazmat/primitives/padding.py", line 101, in _byte_unpadding_check
raise ValueError("Invalid padding bytes.")
ValueError: Invalid padding bytes.
I am about to give up, this really surprised me. I am shocked that backups can be so unreliable. All my recent daily backups are causing this. I think the only option for me is to use the last known working file from a year ago, basically before I moved backups to Google Drive…
When I was trying to delete all the recordings, at the same time I managed to copy most of the data, so I before restoring old backup I will try to manually move everything over to new installation. I imagine it will take a long time to make sure everything works without any major errors.
