I upgraded to 0.97.2 today. When doing so I lost “advanced mode”, I have tried to reboot with “advanced mode” off and on for different users with no luck.
Is it only me?
BR
Tobe
Is it only me?
BR
Tobe
Are you saying that the toggle is missing, or that you can’t find something?
When I go in to my user or any other user on my system, I can toogle between advanced mode and not advanced mode, no problem there, but the advanced menus in “configurations/general” disapeared and will not come back regardless what I do. Rebooting with the advance mode off and on, changing users doing the same. The only additional info I can give is that I installed duckdns add on with out starting it in between. So this is the sequenze. Installed duckDNS addon. Found out there is an upgrade, upgraded. Wanted to check the configuration.yaml could not do it because the advance mode could not be turned on. It is on in my profile, but I can’t see the menues.
BR
Tobe
maybe you are searching for the configuration check tool. It’s now somewhere else.
It’s not in general any more. It’s in “servercontrol” or something like that (don’t know the right term because my UI is german).
BR
Hans
Thanks, there it is!!!
BR
Tobe
where is the check config option? It is not in configuration - server control on mine.
I only have the option to restart or stop in there?
Make sure that Advanced Mode is enabled
Thanks! took a while to find advance mode but sorted now
