System setup: HA OS on a Raspberr Pi3
Current Symptoms:
I don’t have any meaningful access to the installation. Web Ui is broken and it doesn’t show up on the network.
Pinging isn’t working either.
Ping request could not find host homeassistant.local. Please check the name and try again
I’ve tried to hard reboot multiple times and from the output it fails on starting the overlay setup. It also runs a couple of startup jobs. In the end, I’m stuck at a screen with “CLI not starting! Jump into emergency console…”
I cannot press anything on the keyboard to go anywhere to any secondary/ alternative screen.
I have been able to recover some log files, which is how I know the updated got messed up. This is what I have
2024-05-30 18:15:40.488 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546901995072] Error updating Home Assistant Operating System: 'OSManager.update' blocked from execution, system is not running - freeze
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 213, in async_install
await async_update_os(self.hass, version)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 59, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 226, in async_update_os
return await hassio.send_command(
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 593, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: 'OSManager.update' blocked from execution, system is not running - freeze
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 239, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2543, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2580, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 971, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1043, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 162, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 466, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 215, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Operating System: 'OSManager.update' blocked from execution, system is not running - freeze
2024-05-30 18:18:59.842 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-05-30 18:21:31.960 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.sofa_lamp
2024-05-30 18:21:40.762 WARNING (MainThread) [homeassistant.components.automation.toggle] Toggle: Already running
2024-05-30 18:22:32.390 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /supervisor/info - System is not ready with state: shutdown
2024-05-30 18:22:39.891 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-05-30 18:23:28.925 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/update request Server disconnected
2024-05-30 18:23:28.936 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546901995072] Error updating Home Assistant Core
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 304, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 256, in async_update_core
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 614, in send_command
result = await task
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 306, in async_install
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core
- All I have is partial backups that are made before the updates. So even after installing HA OS on a new SD card and trying restore it isn’t going anywhere.
What is that I can reasonably do? I had painstakingly set up a bunch of automations and integrations and currently nothing with even Zigbee is working at home.
