It is rebuilding the ozw_XXXX.xml file containing your device database. In the screenshot you can see the QueryStage, it can take quite some time depending on your network (up to 45 minutes) before it’s all started. Battery powered devices can take some hours up to a day even, unless you manually wake them.
I shut down those devices and everything went back to normal. Now wondering if I should remove/add those nodes to clear the issue or is there something else to do?
Unsure what kind of devices they are to really answer that. But I guess your OZW cache file got pretty corrupted somehow. Good you got it all back online though
