[08:17:40][I][app:100]: ESPHome version 1.14.3 compiled on Feb 1 2020, 16:24:24
[08:17:40][C][wifi:415]: WiFi:
[08:17:40][C][wifi:283]: SSID: 'SSID'
[08:17:40][C][wifi:284]: IP Address: 192.168.#.#
[08:17:40][C][wifi:286]: BSSID: FC:EC:DA:8A:51:3A
[08:17:40][C][wifi:287]: Hostname: 'heizung'
[08:17:40][C][wifi:291]: Signal strength: -63 dB b'[08:17:40]\x1b[0;35m[C][wifi:291]: Signal strength: -63 dB \x1b[0;33m\xe2\x96\x82\xe2\x96\x84\xe2\x96\x86\x1b[0;37m\xe2\x96\x88\x1b[0m\x1b[0m'
[08:17:40][C][wifi:295]: Channel: 11
[08:17:40][C][wifi:296]: Subnet: 255.255.255.0
[08:17:40][C][wifi:297]: Gateway: 192.168.#.#
[08:17:40][C][wifi:298]: DNS1: 192.168.#.##
[08:17:40][C][wifi:299]: DNS2: 192.168.#.#
[08:17:41][C][logger:175]: Logger:
[08:17:41][C][logger:176]: Level: DEBUG
[08:17:41][C][logger:177]: Log Baud Rate: 115200
[08:17:41][C][logger:178]: Hardware UART: UART0
[08:17:41][C][homeassistant.time:010]: Home Assistant Time:
[08:17:41][C][homeassistant.time:011]: Timezone: 'CET-1CEST-2,M3.5.0/2,M10.4.0/3'
[08:17:41][C][dallas.sensor:070]: DallasComponent:
[08:17:41][C][dallas.sensor:071]: Pin: GPIO4 (Mode: INPUT)
[08:17:41][C][dallas.sensor:072]: Update Interval: 15.0s
[08:17:41][D][dallas.sensor:077]: Found sensors:
[08:17:41][D][dallas.sensor:080]: 0x620114500249AA28
[08:17:41][D][dallas.sensor:080]: 0x0401144FA6CDAA28
[08:17:41][D][dallas.sensor:080]: 0x4301144FAB2DAA28
[08:17:41](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[08:17:41][C][dallas.sensor:085]: Device 'Temp Heizk÷rper Vorlauf'
[08:17:41][C][dallas.sensor:085]: Unit of Measurement: '░C'
[08:17:41][C][dallas.sensor:085]: Accuracy Decimals: 1
[08:17:41][C][dallas.sensor:085]: Icon: 'mdi:thermometer'
[08:17:41][C][dallas.sensor:093]: Address: 0x4301144FAB2DAA28
[08:17:41][C][dallas.sensor:094]: Resolution: 12
[08:17:41][C][dallas.sensor:085]: Device 'Temp Heizk÷rper R³cklauf'
[08:17:41][C][dallas.sensor:093]: Address: 0x620114500249AA28
[08:17:41][C][dallas.sensor:085]: Device 'Temp Kessel Bypass'
[08:17:42][C][dallas.sensor:093]: Address: 0x0401144FA6CDAA28
[08:17:42][C][dallas.sensor:094]: Resolution: 12
[08:17:42][C][ota:029]: Over-The-Air Updates:
[08:17:42][C][ota:030]: Address: heizung.local:8266
[08:17:42][C][api:095]: API Server:
[08:17:42][C][api:096]: Address: heizung.local:6053
[08:17:49][D][dallas.sensor:148]: 'Temp Kessel Bypass': Got Temperature=22.2░C
[08:17:49][D][sensor:092]: 'Temp Kessel Bypass': Sending state 22.25000 ░C with 1 decimals of accuracy
[08:17:49](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[08:17:49][D][dallas.sensor:148]: 'Temp Heizk÷rper R³cklauf': Got Temperature=28.5░C
[08:17:49][D][sensor:092]: 'Temp Heizk÷rper R³cklauf': Sending state 28.50000 ░C with 1 decimals of accuracy
[08:17:49][D][dallas.sensor:148]: 'Temp Heizk÷rper Vorlauf': Got Temperature=30.2░C
[08:17:49][D][sensor:092]: 'Temp Heizk÷rper Vorlauf': Sending state 30.18750 ░C with 1 decimals of accuracy
[08:18:04][D][dallas.sensor:148]: 'Temp Kessel Vorlauf': Got Temperature=30.4░C
[08:18:04][D][dallas.sensor:148]: 'Temp Kessel Bypass': Got Temperature=22.3░C
[08:18:04][D][sensor:092]: 'Temp Kessel Bypass': Sending state 22.31250 ░C with 1 decimals of accuracy
[08:18:04](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[08:18:04][D][dallas.sensor:148]: 'Temp Heizk÷rper Vorlauf': Got Temperature=30.2░C
[08:18:04][D][sensor:092]: 'Temp Heizk÷rper Vorlauf': Sending state 30.25000 ░C with 1 decimals of accuracy
[08:18:19][D][dallas.sensor:148]: 'Temp Kessel Bypass': Got Temperature=22.3░C
[08:18:19][D][sensor:092]: 'Temp Kessel Bypass': Sending state 22.31250 ░C with 1 decimals of accuracy
[08:18:19](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[08:18:19][D][dallas.sensor:148]: 'Temp Heizk÷rper R³cklauf': Got Temperature=28.5░C
[08:18:19][D][sensor:092]: 'Temp Heizk÷rper R³cklauf': Sending state 28.50000 ░C with 1 decimals of accuracy
[08:18:19][D][dallas.sensor:148]: 'Temp Heizk÷rper Vorlauf': Got Temperature=30.3░C
[08:18:19][D][sensor:092]: 'Temp Heizk÷rper Vorlauf': Sending state 30.31250 ░C with 1 decimals of accuracy
[08:18:34][D][dallas.sensor:148]: 'Temp Kessel Bypass': Got Temperature=22.2░C
[08:18:34][D][sensor:092]: 'Temp Kessel Bypass': Sending state 22.25000 ░C with 1 decimals of accuracy
[08:18:34](Message skipped because it was too big to fit in TCP buffer - This is only cosmetic)
[08:18:34][D][dallas.sensor:148]: 'Temp Heizk÷rper R³cklauf': Got Temperature=28.5░C
[08:18:34][D][sensor:092]: 'Temp Heizk÷rper R³cklauf': Sending state 28.50000 ░C with 1 decimals of accuracy
[08:18:34][D][dallas.sensor:148]: 'Temp Heizk÷rper Vorlauf': Got Temperature=30.3░C
[08:18:34][D][sensor:092]: 'Temp Heizk÷rper Vorlauf': Sending state 30.31250 ░C with 1 decimals of accuracy
The problem is still alive. As long as i run “esphome.exe heizung.yaml logs” over wifi from my desktop everything is ok. But when i stop the logs the problem returns.
