My HA was running really fine, up until one day when I couldn’t access it’s web interface anymore. It came out of the blue.
After some initial troubleshooting, I realized this happened probably 90 days after I installed the Let’s encrypt plugin. So a qualified guess is that the failure is due to the certificate being expired.
I don’t have HTTP access either, as I removed it for security reasons.
My configuration.yaml:
Good thing is that I have SSH and samba access. So I’m pretty sure this can be sorted, if I would just know how… I’ve made several attempts trying to google an answer, but now after two months without results, I need to get some help here, please.
how did you install HA?
It’s installed using Hass.io image, and then also installed Let’s Encrypt and DuckDNS add-ons. So my installation should be fairly standard.
and have you confirmed your cert suspicions using certchecker?
Opening your browser’s web development console to check what is actually going wrong is even better
I just figured out how to do it and can see that, yes, the certificate for mydomain.duckdns.org expired on 29th of March.
So the solution is most likely to get the certificate renewed. But how do I do that using SSH? I’ve tried to figure out if certbot is available as part of the Let’s Encrypt add-on, but without any conclusions. Perhaps there’s some port I need to open in my router.
(As a side note, I just stumbled on the sensor “Certificate Expiry” - once this issue is solved I’ll for sure add that sensor so I don’t end up in the same situation again)
can you not login via http from inside your network?
Unfortunately not. I remember choosing not to configure that since “why would I ever need it”. I regret that today. I can’t remember what kind of config I choose to remove/not configure unfortunately.
You're about to give https://[my-wan-ip]/ access to your Home Assistant instance.
Logging in with Home Assistant Local.
Error: invalid client id or redirect uri**
sorry have you got access to the same network as the ha host?
then you have another problem which is not the certificate only
your ha is not running correctly.
you need to check your logs
if you have samba you should be able to see your homeassstantl.log
I checked home-assistant.log. Nothing of interest here really, only two entries from two non-relevant plugins having issues.
As said, I do remember intentionally disabling HTTP access. But I don’t remember how.
(BTW, thanks for your patience so far in helping me)
