Hi All, so I was looking for my zigbee network key, but never got to find it, as I messed something up with the file editor and I dont know how to fix it. After a reboot I’m stuk in recovery mode with the following findings that I need help to recover from:
The recovery message:
The log files that I can find:
The configuration.yaml file that I’m able to find, I suspect it should be longer, but I don’t really know because this was my first time using the file editor and I cant seam to find the folders that the file is pointing to, so I suspect I must be doing something wrong… But again I have no clue what went wrong, I tried to use the backup files generated with updates, but that does not seam to change anything… Wiered I thought it was a safe backup that I could use if anything went wrong?
Any help would be much appreciated!
