I have been using Studio Code Server coupled with GitHub for some time, but never checked if GitHub was working correctly.
Separately I used OneDrive to backup my c:\Documents folder under which GitHub stores repositories. OneDrive seems to move the folders to a new location.
When I now go into HA and open SCS I see nothing. I even tried using File Editor and see nothing.
But I can reboot HA with no problem, so I assume that the config files are somewhere, probably where they are expected to be, but I just can’t see them because of the SCS or GitHub settings.
Clearly I am nervous about losing my entire setup, so any and all help is greatly appreciated.
Is there any other information that is required to make the diagnosis easier?
I don’t have the .config but the rest seems to be what I would expect.
But you might be right about some authority settings. I use SambaShare and I have been able to see the config folder from my Windows laptop, but when I try to open it from File Explorer I get a permissions error.
Thanks for the suggestion Dan. Unfortunately I have had Samba running very successfully for at least 12 months. I have been using a different backup solution that runs on an RPi 4 that takes a full backup of the entire HA folder structure.
Since it has been running successfully, I can only assume that something has changed on the HA side. And I have no idea what that could be.
