Hi, hoping someone can help me.
I lost access to my zigbee devices. It appears as though Home Assistant can no longer find my ConBee II USB stick. Haven’t changed anything outside updates so I’m at a loss as to why its not working now.
I am running Home Assistant Supervised with the latest versions (HAOS 10.1 with 2023.4.6) on a proxmox VM. Has been solid and reliable until now.
I can see the ConBee II stick within Proxmox,
But not in Home Assistant.
Here is what the logs are telling me:
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:205
First occurred: 13:25:22 (1 occurrences)
Last logged: 13:25:22
Error setting up entry ZHA for zha
File "/usr/local/lib/python3.10/site-packages/serial/serialposix.py", line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195552-if00'
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 122, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 220, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 205, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 216, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 190, in startup
await self.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 80, in connect
await api.connect()
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/api.py", line 275, in connect
self._uart = await zigpy_deconz.uart.connect(self._config, self)
File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/uart.py", line 134, in connect
_, protocol = await zigpy.serial.create_serial_connection(
File "/usr/local/lib/python3.10/site-packages/zigpy/serial.py", line 37, in create_serial_connection
transport, protocol = await pyserial_asyncio.create_serial_connection(
File "/usr/local/lib/python3.10/site-packages/serial_asyncio/__init__.py", line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.10/site-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/usr/local/lib/python3.10/site-packages/serial/serialposix.py", line 325, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195552-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2195552-if00'
Logger: homeassistant.components.zha.core.gateway
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 13:25:15 (3 occurrences)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
await api.connect()
instance.open()
Can someone point me in the right direction in terms of restoring my zigbee setup?
