Running docker puts the config on a disk on your real machine, as well inside the docker container. It will therefore be preserved if docker is crashed/not running.
If your docker command line is not mapping the config to a real life directory you are not following the instructions.
Thanks, this just saved my bacon! I did the same thing, created a stub, accidentally pasted the full config over the OTA password. I was actually on the way to trying a dissembler when I saw your post. Sure enough, my OTA password was there! Iâm now putting it in my secrets file so that I donât accidentally overwrite it in the future.
Sorry to resurrect this after a few months. Iâm getting the dreaded âESP requests password, but no password given!â
My HA corrupted at the end of last year and iâve had to rebuild some esphome configs that didnât make it into the backups. When I wrote them the first time I didnât set an ota password, but iâm wondering if home assistant had created one internally?
Yeah, thatâs correct. Iâve got four plugs (which I canât seem to open, possibly bonded). Iâve never used an ota password because I didnât realise it was a thing.
They do work, but I want to adjust the configuration including update_interval and tweak the hlw8012 sensor config.
edit: in addition, iâm struggling to connect to the fallback AP. Even though i know the password, and can see the SSID being broadcast. it seems to disconnect immediately. Appears to be the same as âCannot connect to captive portal / fallback hotspotâ, sadly no solution there if weâre unable to flash OTA.
If you read the above posts you will see they want to do this without having to open the case the device resides in. In my case, the ESP device is on a pole 8 feet above the ground and is not easily flash the firmware using a USB cable. The request or question in the OP was how to do using WiFi.
Ok, so iâve just retrieved my OTA password from the .bin file.
First of all I want to say that I know anything about the stuff I use, Iâm just a stubborn with access to Google (Neither am I a native English speaker, so sorry for any typo or grammatical error)
So first of all itâs downloading Cutter (I downloaded for Linux, so I havenât tried Mac or Windowsâs alternatives, but i guess theyâd work the same way)
Then you open your .bin file, youâll see something like this:
Iâve highlighted the OTA password and also just before that thereâs the fallback wifi network password (it wasnât useful in my case as I didnât have captive portal setted up )
Thank you and I hope this is useful for whomever tries to solve this in the future
I just did this by mistake as well to a Merkury light bulb. The API key appears to be correct, just not the OTA one. I have the UF2 file that I had used originally, is there a way to use that?
