I have been using Home Assistant for a year or so now.
I have benn using DuckDns to access Hassio remotely but for a few months now all my attempts to try to access Hassio remotely or understand what is happening have failed.
I have access in the local network, but I cannot access remotely.
I have set up port forwarding on my router (443 to 8123 and 22 to 22) but I cannot access it (remote SSH doesn’t work either).
It seems I can use SSH to access Hassio when I use the phone with data, not connected to the same WIFI as Hassio (I guess the router prevents hairpining).
Errm… your port forwarding is back to front. You want 443 external to 8123 internal. This should show up as port 433 being open.
Also delete that port 22 forward rule. Unless you are using pre-shared keys it is horribly insecure. Use the community web terminal and ssh addon. That way you have only one port open. You remote access Home Assistant the you can open a web ssh terminal from the addon page.
