Decided to upgrade Samba to V8.1 from Windows 10 v1903 from Samba v4. Looks like a lot has changed. I set this up so long ago that I don’t remember what things mean anymore. I got an error in the Samba configuration that I could not figure out so i set it to defaults… On save, I got another error. The defaults don’t have quotes around null in the password setting I discovered. I should think the defaults should not give an error.
I could not remember what username and password are supposed to be set to? Hass.io web page credentials? I tired those. No errors in the Config area of Samba, but no share available either. By the way, my home network uses workgroup name “JSCS”, so that is why it is showing.
Any help appreciated.
Current Config:
"workgroup": "JSCS",
"username": "hass.io login admin username?",
"password": "hass.io login password?",
"interface": "wlan0",
"allow_hosts": [
"10.0.0.0/8",
"172.16.0.0/12",
"192.168.0.0/16"
Here is the Samba log:
[INFO] Read hostname: hassio
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
No builtin backend found, trying to load plugin
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
tdb(/var/lib/samba/winbindd_idmap.tdb): tdb_open_ex: could not open file /var/lib/samba/winbindd_idmap.tdb: No such file or directory
Here is the supervisor log:
19-06-25 16:06:10 INFO (MainThread) [__main__] Initialize Hass.io setup
19-06-25 16:06:10 INFO (MainThread) [__main__] Setup HassIO
19-06-25 16:06:10 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 166
19-06-25 16:06:10 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-06-25 16:06:11 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-06-25 16:06:11 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-06-25 16:06:11 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-06-25 16:06:11 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-06-25 16:06:11 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-06-25 16:06:11 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-06-25 16:06:11 INFO (MainThread) [hassio.host.info] Update local host information
19-06-25 16:06:11 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-06-25 16:06:11 INFO (MainThread) [hassio.host.services] Update service information
19-06-25 16:06:11 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-06-25 16:06:12 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-06-25 16:06:12 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-06-25 16:06:12 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.79.3
19-06-25 16:06:13 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-06-25 16:06:13 INFO (MainThread) [hassio.store] Load add-ons from store: 19 all - 19 new - 0 remove
19-06-25 16:06:13 INFO (MainThread) [hassio.addons] Found 4 installed add-ons
19-06-25 16:06:13 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-addon-samba with version 8.1
19-06-25 16:06:13 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/armhf-addon-duckdns with version 1.0
19-06-25 16:06:13 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/armv7-addon-ssh with version 5.6
19-06-25 16:06:13 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/armhf-addon-mosquitto with version 4
19-06-25 16:06:13 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-06-25 16:06:14 INFO (MainThread) [hassio.snapshots] Found 16 snapshot files
19-06-25 16:06:14 INFO (MainThread) [hassio.discovery] Load 1 messages
19-06-25 16:06:14 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-06-25 16:06:14 INFO (MainThread) [__main__] Run Hass.io
19-06-25 16:06:14 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-06-25 16:06:14 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-06-25 16:06:14 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-06-25 16:06:14 INFO (MainThread) [hassio.addons] Phase 'system' start 1 add-ons
19-06-25 16:06:14 WARNING (MainThread) [hassio.addons.validate] Unknown options plain
19-06-25 16:06:14 WARNING (MainThread) [hassio.addons.validate] Unknown options ssl
19-06-25 16:06:28 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-mosquitto with version 4
19-06-25 16:06:29 INFO (MainThread) [hassio.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
19-06-25 16:06:29 INFO (MainThread) [hassio.discovery] Duplicate discovery message from core_mosquitto
19-06-25 16:06:33 INFO (MainThread) [hassio.addons] Phase 'services' start 3 add-ons
19-06-25 16:06:54 INFO (SyncWorker_17) [hassio.docker.addon] Start Docker add-on homeassistant/armhf-addon-duckdns with version 1.0
19-06-25 16:06:58 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-06-25 16:06:59 INFO (SyncWorker_11) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-ssh with version 5.6
19-06-25 16:07:04 INFO (SyncWorker_18) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-06-25 16:07:58 INFO (MainThread) [hassio.api.security] /homeassistant/restart access from core_ssh
19-06-25 16:07:58 ERROR (MainThread) [hassio.utils] Can't execute restart while a task is in progress
19-06-25 16:08:23 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-06-25 16:08:23 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-06-25 16:08:23 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-06-25 16:08:23 INFO (MainThread) [hassio.core] Hass.io is up and running
19-06-25 16:08:24 INFO (MainThread) [hassio.api.security] /homeassistant/restart access from core_ssh
19-06-25 16:08:24 INFO (SyncWorker_8) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
19-06-25 16:10:14 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
