Wanted to see if anyone else if having this issue. I just upgraded to 2022.2.2 and I can no longer edit my device names. The name is greyed out and can’t be changed.
Anyone else having this issue? I’m considering rolling back but want to know whether it’s something I did or an actual bug
Ok, super strange, I haven’t been able to update these all night but I just went back in and the option was no longer grey. So, I tried to update the name and the dialog box hung open and no change was made. I had to click outside of the dialog to make it go away.
Found this in the logs after:
2022-02-05 00:32:43 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139692437681440] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/config/device_registry.py", line 66, in websocket_update_device
msg["disabled_by"] = DeviceEntryDisabler(msg["disabled_by"])
File "/usr/local/lib/python3.9/enum.py", line 384, in __call__
return cls.__new__(cls, value)
File "/usr/local/lib/python3.9/enum.py", line 702, in __new__
raise ve_exc
ValueError: None is not a valid DeviceEntryDisabler
2022-02-05 00:32:43 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
raise ve_exc
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 29, in _handle_async_response
connection.async_handle_exception(msg, err)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/connection.py", line 143, in async_handle_exception
self.send_message(messages.error_message(msg["id"], code, err_message))
KeyError: 'id'
Now the option is grey again and I can no longer make the change.
What I did to get it working again was install the backup that was auto created before updating to
2022.2.2.
I unchecked the ‘Folders’ and 'Home Assistant configuration" so only the 2022.2.1 core would be the only change.
