My cat in a panic attack knocked my PI 4 from my desk. And caused the Z-Stick Gen 5 (old version) to come out. Now this stick is connected via a USB adapter (because it does not work when connected directly to the PI). That adapter has 4 ports.
The error I get is:
Failed to set the Z-Wave JS add-on options: not a valid value for dictionary value @ data[‘options’]. Got {‘device’: ‘/dev/serial/by-id/usb-0658_0200-if00’, ‘s0_legacy_key’: …
Question 1, does it matter which port of the adapter is used? Or is that usb address specific for one of the ports?
In terminal when I do ‘lsusb’ I get this:
It is not showing any devices connected to these usb ports. And one port has the USB adapter and the other a SSD.
How can I figure out what is wrong? I assume the stick is working fine.
